Welding Capacity Calculation 7
JohnRwals
151
Hello!
P1 and P2 have exactly the same conditions except top, bottom horizontal welding.
I thought P2 could support greater vertical load.
But...
Which one do you think can support greater load? Why?
Thanks!
JW
R
CANPRO said:
P2 would be better if you could flip the angle and put the vertical leg down and keep the weld on top.
Lomarandil said:
I agree P2 with the angle flipped (or stiffened) is the highest capacity configuration.
Do not agree with these statements if your going to rely on the compression development between the angle and the embed then flipping the angle so the flexible leg vs the rigid heel works to develop the compression block is an inherently worse condition.
My Personal Open Source Structural Applications:
Open Source Structural GitHub Group:
Lo,
I guess I understand the stress concentration/raiser problem at the weld corner. My mistake to use such example. But even with breaking up the weld lines, will both case stay the same? Please show me the "correct" method, thanks.
You think so Celt? I think your concern might be analogous to a concrete beam -- even if the leg is flexible and decreases the moment arm to the compression/bearing region, that's of less effect than the much larger area of weld (rebar) stressed in tension.
(For clarity, my comment is dealing entirely with the moment eccentric to the embed face. I'm not concerned here with the shear parallel to the face.)
just call me Lo.
CANPRO said:
For P2, I don't think the horizontal weld is fully effective until the vertical welds start to fail. Think about how the angle has to deform to deliver load to the horizontal weld...you would develop separation between the angle and embedded plate, which can't happen because of the vertical weld.
By this same logic you wouldn't develop any compression bearing with the embed until the vertical welds start to fail. Under the assumptions of an elastic analysis the strain at the tip of the vertical welds is constant across the horizontal weld so the weld experiences stress.
CANPRO said:
For P1, the horizontal weld does nothing if the angle is placed firmly against the embedded plate
agree, however in my experience more often than not the embed plate is askew and the angle seat is constructed with some small gaps filled with weld material. So so you'd need to work thru the weld deformation prior to engaging the plate in bearing, so the conservative design capacity would only consider the welds effective, then I have the bearing compression block as back pocket help if needed.
DIK said:
and to reiterate... it's easier to weld... seems like a win win situation.
If we are talking about field welds absolutely agree, if were talking about a shop weld the weld to the angle toe probably requires more material as its flare bevel weld because the toe fillet vs standard fillet at the right angle heel. If this is Bent plate and not an angle then I am in full agreement with your statement.
R13, your illustration shows all that is needed (I haven't checked your math).
For load in the downward direction, parts in initial contact, and a sufficiently stiff angle (which may or may not be present), the peak tensile stress is at the top of the weld group.
As you illustrate, because of the neutral axis location, the tensile stress (stress=M/S) at the top is lower for the "P2" configuration (your 0.023 when using a unit moment) than P1 (0.035)
As a general rule, I'm rarely concerned with the compressive stress in cases like this because of the possibility of bearing between the angle and embed plate (e.g. the weld isn't loaded). So I would check the combined tensile and shear stress at the top of the group and call it a day.
(Of course, some rare geometries and/or applications will change the validity of that last statement.)
just call me Lo.
If you go with this analogy a smaller moment arm begets larger tension/compression couple forces required for equilibrium which results in higher tensile stresses in the weld.
Lo said:
R13, analyzing stresses in a weld group as equivalent couple forces is not a correct approach.
The method used was the classic elastic method for stress analysis, with the weld treated as a line. I don't know another method/approach, and would like to learn. Can you share, please.
You are entitled to your approach, but it's something I wouldn't do - weld the tension side only. Is this statement sounds "incorrect" or "misleading", please advise.
The weld design will be done by 2 steps without calculating all that properties and stresses - weld for tension, and weld for shear. But this forum is not the place to advocate for design short cuts, unless it is a discussion between two members that fully aware what they are talking about. When you want to criticize somebody else's comment, it's fine, but please be clear, don't play opinionated/sentimental word games.
Suppose we eliminate the vertical welds in P1 and P2. Which carries more load?
BA
BAretired.
P2 would carry more load because P1 would probably be on the floor!
P2 carries more because P1 will carry zero. P1 would pivot on the horizontal weld.
Celt83, I saw your reply to my comment...pretty busy so I didn't read over that closely, but I hope to later.
How about take away the horizontal weld for both case, which one is better?
Okay, so the horizontal weld in P2 is better placed than the one in P1; so why is this not still true when vertical welds are added?
BA
They would be identical, r13, so the failure loads would be the same.
BA
Suppose we are connecting an HSS with point load at the free end to a rigid support and weld in the P1 or P2 pattern using a 3/8" fillet weld. Which would support more load assuming equal distance from support to load?
BA
BA,
I don't get that. The geometry center of the angle does not align with weld center then. Can you elaborate your view?
It boils down to if you want to consider bearing compression development between the beam (angle, HSS, etc.) and the embed. I'm of the opinion that the load-deformation response of a weld is such that if you have even a 1/16" of separation you need to rely on just the weld for the load transmission.
If you allow compression bearing development:
P2 will always result in the higher capacity
If you do not rely on compression development between the beam and embed and define failure as weld rupture:
P2 and P1 have equal design capacity
P2 is ultimately a safer condition because after you reach the failure criteria of the vertical weld lines in compression you then have the additional redundancy of the compression bearing development creating an additional load equilibrium condition.
Celt83 said:
BA[/color]]It boils down to if you want to consider bearing compression development between the beam (angle, HSS, etc.) and the embed. I'm of the opinion that the load-deformation response of a weld is such that if you have even a 1/16" of separation you need to rely on just the weld for the load transmission. What can I say, other than I don't agree? No one is going to leave a gap between angle and embed plate.
P2 will always result in the higher capacity. Correct
P2 and P1 have equal design capacity. Perhaps, but how many engineers would do that?
P2 is ultimately a safer condition because after you reach the failure criteria of the vertical weld lines in compression you then have the additional redundancy of the compression bearing development creating an additional load equilibrium condition. Indeed!!
BA
