Definition of a concrete columns vs. a wall
WillisV
1,352
Could someone provide me with a code reference that indicates when a certain member is defined as a column vs a wall (aspect ratios etc?). Looking more as it pretains to min. reinforcing provisions and fire rating applications as opposed to strength design.
ACI 530 doesn't seem to have a problem explicitly specifying the definition as a ratio...
WillisV: Not to slag concrete masonry, but the results of an ACI530 design are more predictable, and (typically) simple, than for ACI318. Probably has a lot to do with the willingness to define a ratio...
Cheers,
YS
B.Eng (Carleton)
Working in New Zealand, thinking of my snow covered home...
