TTFN (ta ta for now)
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Alistair_Heaton said:If your interested the word on the street is that it was an Auto throttle clutch issue on one side which put the aircraft into an asymmetric power situation.
Littleinch said:OK, I can see how this wouldn't be good, but how does it result in the airplane diving into the sea?
This exchange brought to mind a new video I just saw and is a week old. This well known incident was not a 737 but a 747-SP, asymmetric thrust, and it wasn't the auto throttle clutch but a sluggish fuel control valve, made worse by crew errors. Autopilot was at maximums when the pilot took over not realizing the trim state the autopilot had the aircraft in.Alistar_Heaton said:Failure to apply corrective control inputs in a timely manner after the systems dump a very out of trim aircraft onto the pilot... But those that have tell me its quite aerobatic.
