why bend can not go more than 53 deg in nx8.5 sheet metal bend
Ehaviv
Computer
IL
Hi
Can anyone explain why the flange bend see picture can not reach 90 deg
and stack at 53 deg
but when I change exp p29=12 to p29=8 its reach 90 deg
the part is also atached
I am not expert in sheet metal module. I tried your model and it seems to be able to bend 90 degree.
Change "Reverse Side" direction.
BW
Hi bw and thank you for the response.
but I was seen this in my playing with the part
but that flipped my sketch location
and make me afraid to my part on something
not sure.
Thak you very much.
To continue building my part on something not sure.
Thank you Deedub777
I succeeded to build my bracket.
I only was curious of that phenomena.
