linked parent not showing in assembly 1
dbharness
I have a component i used for a linked body. When i un-suppress the component is not visible. I can see everything (Entire Part ref set) except the component body.
I don't remember this behavior in the past.
Is there a setting. Other users in my office are not having this issue.
NX 11.0.2.7, Teamcenter 11 (11.2.3.1_a01_4(20170824.00)) 64-bit
Try this: show/Hide -> show... -> select all solid bodies.
It is possible to hide the solid body of a component, independent of the component. When this happens, using show/hide on the component itself will have no effect.
