I was designing a replacement vessel where
the flanges of the existing vessel were RFSO which allowed some compact design.
For the new vessel however the client has specified that RFSO are no longer acceptable and only RFWN or RFLWN are acceptable.
If I tried to substitute two of the main 20"NB flanges with WN the proximity of the flange to neck and neck to shell welds became too small.
So I thought I'd save us the hassle and opt for RFLWN flanges instead.
Now project engineers reported that RFLWN flanges will cost as much as 5 times more to buy in comparison to standard ASME B16.5 RFWN.
Flange material is ASTM A350-LF2-1.
I appreciate the fact that RFLWN is twice heavy and twice long compared to RFWN but there's no way I can justify
such great difference in cost in my mind. Especially for something that involves similar repetitive forging process,
similar machining and drilling process...
I'd think that 2 times or 3 times should sound reasonable but 5 times?
Is there such great difference in manufacturing process that would justify 5 times higher cost of a RFLWN flange?
Thanks!
Thanks!
