ElCidCampeador
Hello, I've read many threads in this forum about set-in/set-on nozzles and what is the "best" solution for a pressure vessel.
I usually design according ASME VIII Div.1 but this code seems not to suggest a preference for a insert or a set-on configuration as long as you follow figure UW-16.
But from a "SIF" point of view, it seems to me that a set-on weld is worse than inserted. Do you know any research paper or standard that I can read about?
I've read B31J (which was appendix D of ASME B31.3) , e.g. table 1-1, but I don't understand sketch shown and "Run SIF" defined. What am I supposed to take away from all this? Please help me, thank you.
