Honda Recall - 3.5L main bearing problems
I joke sometimes that a sign of good quality control is that every vehicle has the same problems because they are built so consistently. Quality control doesn't fix engineering oversight.
I get framing this as a joke, but it's pretty damn accurate.
In my past life as a designer of equipment, we had a similar mantra - which was 'A bad process is just as easy to get under fine control as a good process'.
Sometimes the process design itself is the problem, and you don't know it's bad until you've built enough product to see the low rate issues appear.
Well it depends on the level of experience of engineers and the support group.
Which I am surprised Honda is having issues.
Data or science is only as good as its sound
Accurate data collected.
Here's what we know , there is a recall, so there's an issue. We don't have enough information until we dig up the actual facts.
We actually don't know that there is an issue.
The original article and the later linked article about GM 6.2 engines are both reporting on NHTSA investigations, not recalls. Investigations can turn into recalls, but they aren't the same thing.
Well wait and see. What the investigation determines.
But it could be minor or major otherwise why open an investigation. And why recall.
To repeat, the cited root cause for the Honda case referenced was ". . . defective (convex/concave) grinding of the crank pins due to mis-setting of manufacturing CNC leading to main bearing failures." Which sounds pretty factual unless there is cause to doubt the veracity. What that could have to do with design defects or swarf in the oil is not readily apparent. It would appear the only process needing better control involves ensuring data integrity between the design output into the actual CNC mills making the physical parts.
Every manufacturers's reliability is declining. Cars are getting way more complex to meet ever increasing govt. standards and buyer'd wishes for tech and low price. I feel like Ford is the worst right now though.
Not just Honda, so many other brands having the same issues. And the cause? Most all the causes are in plain site and no one can see it. :unsure:
