  • Congratulations 3DDave on being selected by the Eng-Tips community for having the most helpful posts in the forums last week. Way to Go!
Honda Recall - 3.5L main bearing problems 1
A minor issue on a few years of one variant, of one engine, in one of the most-produced engine families, known for reliability in everything from 3rd world cheapies to 1st world supercars.
Not true at all.Timing chains and phasers. Watch Ford Tech Makuloco's videos.
The problem here is that many are relating their experiences with NBR or EPDM rubber to HNBR rubber which is quite a bit more durable under hot engine conditions. You can't blame the rubber for incorrect specification.
As for engine room fires, lube oil and diesel fuel both have lower auto-ignition temperatures than gasoline. Fires do happen. I've had one. It was a lube oil fire that ignited when a steel line broke.
I imagine whoever designed the belt (Gates maybe) is well versed in hot versus warm conditions. Seems like it is more not finding a mix that will tolerate all the chemicals in used engine oil for that amount of time/miles. Although, Honda has been using wet belts in their small equipment engines for decades - which notoriously have dirty oil.. Have not heard many issues with them although the consequences of a broken belt in that application is not much.
