SCL's almost always have better stress and deflection ratings than GLB, so if you spec GLB, a equal size SCL swap is easy. Truss Joist makes products called PSL, LVL, and LSL. When I spec them on plans, it's in reference to that specific manufacturer, with a not that any substitution requires approval by me, as they are not all created equal.
As far as avoiding RFI's go, Your best bet would be to figure out what the contractor wants and spec it. Past that, you can make them EASIER by spec'ing GLB's, and then most all SCL will have superior values (providing the camber and moisture differences are a non issue as pointed out above), or use minimum values of SCL so most anything will work.
You can put the design values used in the plans and leave the product selection up to the contractor, but I wouldn't recommend it, since they may not know/understand all the implications of what they're looking at.
