I have a dwg with a model as a component. I did not create this assembly.
The model is in work layer 254, and I have the reference set as "entire part" and I still cannot see the model. I have un-hide everything and change the background in case it is the same color as the model. Using NX9. I notice that the component icon is a bit different than normal. Looks like there is a sheet behind the yellow cube.
Thanks!
UGNX 8 / 8.5 / 9 - Windows 7 64bit
Productive Design Services
Thanks!
