slickdeals
The title of my post says it all. Please see attached sketch.
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
MarkHirschi said:So there's shear at the interface, but no shear 1" away from the interface? How does that work?
MarkHirshi said:Say we had a load directly over the waypoint instead, so we'll take out any sort of beam action in the tension tie. Load goes applied straight down and then converted into an axial load in the brace and a tie force in the tension tie. There's no shear between tie and brace there.
MarkHirschi said:But if you apply the shear friction limits provided in the code, you're still going to fail every time.
MarkHirschi said:Okay, so a shear at some plan other than normal to the axial member's axis. If this were a column oriented vertically with only axial load, no shears, no moments, no slenderness concerns, would we be checking that?
