WildcatHerb
Automotive
Why can't I create an assembly constraint which references an existing datum point with NX-8.0?
If I select other types of points ie. end point, mid point, or circle center there is no issue.
However if I try to select an existing datum point NX displays a alert "The point references an invalid geometry and cannot be used in a constraint.
Am I missing something? Has anyone else found a way around this issue?
