Plate to Plate contact in FEM model
I need to make an FE model of a small plate (Plate A) placed above another plate structure (Plate B). Plate A is attached with an I beam. I will give a load in the I beam. How can model this? Please see the attached image. Promlem is in FE, I can not create a plate which has contact with another.
Thanks in advance.
FE modeling Tool use: SESAM/GeniE
Habib
RE: Plate to Plate contact in FEM model
well I do not know your FE Program....but I use RFEM ( https://www.dlubal.com/en ) and I can do this easy
What is the purpose of your analysis? Have you tried create elements above and below, and link the elements by rigid links?
Are you doing a macro-level structural analysis or a detailed component-level stress analysis?
suggest posting in the FE forum.
You have a load in the I-beam, which travels through plate A (a spreader) and is reacted by "plate" B … and you need to FEA plate A ?
or plate B ? (the performance of plate A should be measured by how well it distributes the concentrated load over an area of plate B).
if you Have to FEA it … isn't this a simple contact problem ?
Seems to be a straightforward contact analysis. Provided, of course, that the software can do this.
If you don't know, why not simply ask the vendor that you bought the license from? And if it can't, that contact should not be to difficult to simulate without using contact elements.
Thomas
The point of my previous reply is that there are many types of FEM. In a macro-level structual model, you would probably attack this using rigid links, similar to this: Link. Detailed FEM where you are modelling each beam, column and base plate with plate elements under contact is a whole other proposition.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - PLM and ERP: Their Respective Roles in Modern Manufacturing
Leading manufacturers are aligning their people, processes, and tools from initial product ideation through to field service. They do so by providing access to product and enterprise data in the context of each person’s domain expertise. However, it can be complicated and costly to unite engineering with the factory and supply chain. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
