TIA - Wind Gust Effect Factor
Any of you familiar with the TIA might help me in verifying something...
Looking at wind loads on appurtenances and the gust effect factor.
REV-H of the standard has the factor for structures laid out in section 2.6.7. Paragraph 3 of 2.6.9 then states that the gust effect factor for design of appurtenances and their connections shall be 1.0.
It appears that this direction to use 1.0 for appurtenances was removed in REV-G and you are reverted back to the structure type...which makes sense.
Can anyone confirm the above? Or was something shuffled around in the latest code and I'm missing it elsewhere?
RE: TIA - Wind Gust Effect Factor
One bump for the large Monday cohort that is well versed in the intricacies of the TIA code. Then I'll let this die its withering death on the vine. :)
So, TIA-222-G actually defined the Gh for appurtenances as well, but in a very round-about and obscure way.
TIA-222-G 2.6.9 Paragraph 3 states the following:
'for the strength design of appurtenances and their connections . . . a gust effect factor of 1.0...'
In short, the Gh and Kd values explicitly stated in Chapter 16 in TIA-222-H were taken from TIA-222-G but more clearly defined, in order to avoid the confusion in G when it came to antenna mount analyses and what parameters to use. What ended up being called a 'mount' in TIA-222-H fell under the scope of 'strength design of appurtenances' in TIA-222-G. Confusing, I know, which is part of why Chapter 16 was added in to H, in order to provide clarity regarding antenna mount analyses.
Hope this helps!
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
White Paper - A Guide to 3D Printing Materials
When it comes to using an FDM 3D printer effectively and efficiently, choosing the right material at the right time is essential. This 3D Printing Materials Guide will help give you and your team a basic understanding of some FDM 3D printing polymers and composites, their strengths and weaknesses, and when to use them. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
