gregroberson
- Jan 20, 2010
- 8
I am an EIT trying to determnine the responsibilty of X-bolt direction during erection in the field. Does the direction of the X-bolt fall under means and methods or is it the responsabitlity of a steel detailer to indicate direction in addition to indicated the type.
Acting as a connection engineer and steel detailer hired by a fabricator, If I design a connection that required X-bolts, I obviously have to clearly indicate X-Bolts required on steel erection and shop drawings.
However, should the steel erector (AISC cert. or not)be aware to install the X-bolt with the bolt threads excluded from the shear plane? If not, would the steel detailer be required to "show" the bolt direction for each and every connection instance I have X-bolts in?
Any thoughts would be appreciated.
Greg
Greg
