witch Assembly constraint do the trouble and blocks the others
Ehaviv
Computer
Jul 2, 2003
1,012
Hi
I have an Assembly with many constraints
and when come to add a component I can do a constraint
but the positioning not applied
And I do not know witch ones to delete to free
This blocking.
Thank you for any help
The constraint navigator will show you which constraints are conflicting..
The conflicting constraint shows a traffic sign icon..
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
HP Zbook15
Intel(R) Core(TM) i7-4800MQ
CPU @ 2.70 GHz Win7 64b
Nvidia K1100M 2048 MB DDR5
Hi
But
In The constraint navigator all the constraints are
marked by a yellow icon see the image in this post
and so I can not see witch the first constraint make blocking
the others (suppress and unsuppress is bad way and I do not know if will help)
nutace Thank you for any help
 http://files.engineering.com/getfile.aspx?folder=07acd213-e130-40da-979f-2eaa1947fcf7&file=outofdateicon.jpg
First make sure all of your components are fully loaded. At least NX will then be able to solve the constraints which are correct.
NX9 / TC10.1.2
HP Zbook15
I feel this will help
Thank you very much
Because I have two weeks to get back to my work
to check that meanwhile the thought push me ahead
To ask
Do wave link freeze (in our ccompany we do freeze before dwg release)
Can do this ? Do if I unfreeze can removes this
Out of date icons
What exactly do you mean with Freeze?
NX9 / TC10.1.2
HP Zbook15
Assemblies ==> WAVE ==> Associativity Manager
and on the opend dialog I press 'Edit Frozen Status' Button and then on the opened dialog
I move the assembly parts master and non-master to the 'Persistent Frozen Parts' window
and OK the dialog
That might be a cause as well..I am assuming, because the link is frozen NX can't get the correct status of the wave parent..
NX9 / TC10.1.2
HP Zbook15
