Carbonated
Bioengineer
- Apr 24, 2023
- 7
Hi all,
I'm trying to position a convergent body onto an assembly. The body has a cylindrical face on one of its extremities. I'm trying to position the other end using a fitted surface and setting a safety distance of 5mm between the surface and the component below.
Despite the cylindrical constraint leaving me one degree of freedom (rotation), and the convergent body rotating colliding with the component below (meaning the distance can be above and below
Probably the software tries to move the body rather than rotate it around the cylindrical face in order to meet the specified distance.
I currently am doing this positioning manually, but it is lengthy and imprecise. Is there any way to achieve this with normal constraints?
Thanks in advance,
Thanks in advance,
