Reference for your Technical Library piping
National Standard of the People’s Republic of China
1. GB 12337-1998 Steel Spherical Tanks
ARCHITECTURAL INSTITUTE OF JAPAN
2. DESIGN RECOMMENDATION FOR STORAGE TANKS AND THEIR SUPROTS 1996 EDITION – Earthquake Resistant Design of Storage Tanks and Their Supports -
ASME CODE:
1. ASME International ASME Boiler & Vessel Pressure Code ZCD699
2. ASME B31.1 Power Piping
3. ASME B31.3 Process Piping
4. ASME SECTION I Rules for Construction of Power Boilers,
5. ASME SECTION IV Rules for Construction of Heating Boilers,
6. ASME SECTION V Nondestructive Examination,
7. ASME SECTION VIII Division 1, Rules For Construction Of Pressure Vessels
8. ASME SECTION IX Qualification Standard for Welding and Brazing Procedures, Welders, Braziers, and Welding and Brazing Operators.,
9. ANSI/NB-23 National Board Inspection Code
Mechanical Engineering Reference Manual:
1. PRESSURE VESSEL HANDBOOK, Thirteenth Edition
2. Boiler Operator’s Guide, Fourth Edition, Anthony L., Kohan
3. GUIDEBOOK FOR THE DESIGN OF ASME SECTIN VIII PRESSRE VESSELS by James R. Farr and Maan H Jawad
4. Process Piping The Complete Guide to ASME B31.3 Charles Becht IV
5. ABOVEGROUND STORAGE TANKS, Philip E. Myers.
6. Pressure Vessel Design Manual Second Edition, Dennis R. Moss
7. Pressure Vessel Design Manual Third Edition, Dennis R. Moss
8. TEMA STANDARDS OF THE TUBULAR EXCHANGER MANUFACTURERS ASSOCIATION SEVENTH EDITION
9. TEMA STANDARDS OF THE TUBULAR EXCHANGER MANUFACTURERS ASSOCIATION EIGHT EDITION
10. Process Plant Layout and Piping Design Ed Bausbadher & Roger Hunt
11. Engineering Design for Process Facilities
EIT & PE Professional Engineering Examination Problem Solutions
12. Solutions Manual for Mechanical Engineering, Michael R. Lindeburg, PE
13. 1001 Solved Engineering Fundamentals Problem, Michael R. Lindeburg, PE
14. Mechanical Engineering Reference Manual Ninth Edition, Michael R. Lindeburg, PE
15. Engineering-In-Training Reference Manual Eight Edition, Michael R. Lindeburg, PE
16. NAVCO PIPING DATALOG, National Valve and Manufacturing Co.
17. PRUESURE VESSEL DESIGN HANDBOOK Second Edition, Bednar.
10. Boiler Inspection Guide, Indiana Department of fire and Building Services Office of the State Building Commissioner Division of Boiler and Pressure Vessel Safety.
11. Design Manual for Two Phase Gas-Liquid flow in Pipelines, American Gas Association and API.
12. Thermal and Seismic Stress and Fatigue Assessment of a Helical Heat Exchanger Type ASME Pressure Vessel.
13. Seismic Evaluation of Recovered Gas Dryer Support ASME Pressure Vessel.
14. Structural Engineering Handbook Edwin H. Gaylord, Jr. and Charles N. Gaylord.
15. A Practical Guide to Pressure Vessel Manufacturing, Suin Kumar
16. ASNT’s International Chemical and Petroleum Industry Inspection Technology (ICPIIT) IX Conference June 1-4, 2005 Hyatt Regency Houston Airport Houston, Texas, USA
17. General Procedure For Designing Piping Supports Chemical and Petroleum Plants
18. Mechanical Design of Process Systems Volume 1, Piping and Pressure Vessels, A Keith Escoe
19. Mechanical Design of Process Systems Volume 2, Shell-and –tube Heat Exchangers rotating Equipment – Bins, Silos, Stacks, A Keith Escoe
20. Piping Support Design Guide for Nuclear Power Plants by S L Lee
21. CIBO Energy Efficiently Handbook, Counsel of Industrial Boiler Owners (CIBO) 1998
22. Stress Analysis Layout Considerations for Piping Designers, Rafik Kulyye Brown and Root Energy Services October 1998.
23. PIPING DESIGN and ENGINEERING ITT Grinnell Industrial Piping
24. Practical Guide to ASME B31.3, Process Piping Glynn E. Woods & Roy B Baguley
25. THE M.W. LELLOGG COMPANY DESIGN MANUAL-PIPING MECHANICAL
26. THE M.W. LELLOGG COMPANY DESIGN VESSEL STRUCTURAL STEEL
27. The Piping Guide, A Compact Reference for the Design of Piping Systems
28. Flow of Fluid Through Valves Fitting and Pipe Crane Technical Paper 410
29. DYNAMIC ANALYSIS
ASME STS-1 APPENDIX 5.A RESPONSE SPECTRA ANALYSIS
30. Site Maintenance Department Mechanical Integrity Program Manual
31. Modern Welding Technology Third Edition Howard B. Cary
32. Structural
Matrix Analysis of Structures, Robert E. Sennet
33. First International Symposium on Process Industry Piping, Dec. 14-17 1993
34. Steel Design Handbook, LRFD METHOD Akbor R. Tamboil
35. Manual f Steel Construction Load & Resistance Factor Design Volume I
Structural Members Specification & Code
Manual f Steel Construction Load & Resistance Factor Design Volume II
36. Connections Route Location and Design
37. Control Valve Handbook, Fisher
38. Machinery’s Handbook 16th edition
39. Design of Piping Systems, The M.W. Kellogg Company 1956.
40. Deign of Weldments Omer W. Bldgett
41. Solutions to Design of Weldments D810.17, Omer W. Bldgett
42. Design of Welded Structures. Omer W. Bldgett
43. 8th International Seminar In Piping Design And Piping Stress Analysis May 5-9 1986 Texas A&M
44. HEAT EXCHANGER INSITIUTE ADDENDUN 1 STANDARS FOR STEAM SURFACE CONDENSERS EIGHT EDITION
NACE REFERENCE
45. CORROSION ENGINEERING Fontana and Greene
46. The Corrosion Handbook, Herbert H. Uhlig
47. Process Instruments and Control Handbook
48. Localized Corrosion NACE Publication
49. METALS SECTION Corrosion Data Survey
50. The Vanderbilt Rubber Handbook
51. Process Piping Design Volume 2, Rip Weaver
52. Hook-Up Design For Steam & Fluid Systems, SARCO CO.
MTI Publication
1. Inspection Guidelines for Pressure Vessels and Piping Volume 2: Manual and Pocket Guides MTI Publication 49
2. User’s Guide to ASME Standards for Fiberglass Tanks and Vessel MTI Publication No. 50. RTP-1 and ASME Section X.
AWS AMERICAN WELDING SOCIETY
1. WELDING INSPECTION
2. AWS Welding Inspection Technology
WELDING RESEARCH COUNCIL
1. WRC BULLETIN 107
2. WRC BULLETIN 297
3. Local Stresses in Cylindrical Shells Due to External Loading on Nozzles Supplement to WRC BULLETIN 107 (Revision 1)
4. WRC BULLETIN 198
Secondary Stress Indices for Integral Structural Attachments to Straight Pipe-
Stress Indices at lug Supports on Piping Systems ETIN 297 LOCAL STRESS IN CYLINDRICAL SHELLS DUE TO EXTERNAL LOADING ON NOZZLES SUPPLEMENT TO WRC BULLLETIN NO 107 (REVISION 1)
5. WRC BULLETIN 329 Accuracy of Stress Intensification Factors for Branch Connections
6. WRC BULLETIN 330
The fracture Behavior of A588 Grade A and A572 Grand 50 Weldments
Effect Of Long-Time Postweld Heat Treatment On The Properties Of Constructional –Steel Weldments
7. WRC BULLETIN 368 Stresses in Intersecting Cylinders Subject to Pressure
8. WRC BULLETIN 406
9. WRC BULLETIN 414
10. WRC BULLETIN 417 DESIGNGIDE TO REDUCE POTENTIAL FOR VIBRATION CAUSED BY FLUID LOW INSIDE PIPES-REVIEW AND SURVEY.
11. WRC BULLETIN 429 3D Stress Criteria Guidelines for Application
12. WRC BULLETIN 435 Evaluation of Design Margins for Section VIII, Div 1. and 2 of the ASME Boiler and Pressure Vessel Code
13. WRC BULLETIN 444
14. WRC BULLETIN 448 January 2000 Evaluating of Welded Attachment on Pipe and Elbows
15. WRC BULLETIN 449 Guides for the Dewing and Installation of Pump Piping Systems
16. WRC BULLETIN 497 LARGE DIAMETER ROATION SHELL INTERSECTIONS
Part 1: Design of Large Diameter Ratio Shell Intersection Subject to Pressure and External Loading
Part 2: Parametric finite Element Analysis of Large Diameter Shell Intersections (Internal Pressure)
Part 3: Parametric finite Element Analysis of Large Diameter Shell Intersections (External Loadings)
Brown & Root Associate Company Metric Unit Pipe Wall Thickness Comparison Table.
Pressure Vessel and Piping Conference:
1. New Common Design Rules For U-Tube Heat-Exchangers in ASME,CODAP AND UPV CODE, Francis Osweiller
2. A Proposed ASME SECTIN VIII, DIVISION 1, TUBESHEET DESIGN PROCEDURE.
3. ANALYSIS OF TEMA TUBESHEET DESIGN RULES- COMPARISIONWITH UP TO DATE CODE METHODS
4. Part UHX White Paper, Urey R. Miller
5. Pressure Vessel Design, Nozzle Piping Reactions
6. Piping Reaction on Pressure –Vessel Nozzle
7. External Load on Nozzle
SEMINAR by CODEWARE pressure vessel & heat exchanger software
1. ASME SECTION VIII DIVISION 1 PRESSURE VESSEL DESIGNAND FABRICATION September 13-15 2004 Instructor –Kam Mokhtrian, P.E.
2. ASME SECTION VIII DIVISION 1 PRESSURE VESSEL DESIGNAND FABRICATION February 22-24 2006 Instructor –Kam Mokhtrian, P.E.
3. Inspection, Fitness-For Service Flow Evaluation and Repair of Pressure Equipment, December 6 – 10, 2004 Instructor –Kam Mokhtrian, P.E.
4. ADVANCE DESIGN, ANALYSIS AND FABRICATION OF PRESSURE VESSEL ASME SECTION VIII DIVISION 2 PRESSURE VESSEL ANDOTHER INTERNATIONAL CODES AND STANDARDS APRIL 25-29 2005 Instructor –Kam Mokhtrian, P.E.
5. Introduction to COMPRESS for Windows February 21, 2005 Instructors Thomas E, Barsh P.E., Mike Van Truong
SEMINAR by CODE Engineering Software:
Pipe Stress Analysis November 8, 9, 10, 1988, Houston, Texas
CAESAR II STATIC ANALYSIS PIPE STRESS SEMINAR NOTES 1998
CAESAR II DYANIC ANALYSIS PIPE STRESS SEMINAR NOTES 1998
PVelite Vessel Design & Analysis Seminar Notes 2003
PVElite/CODECALC QA manual revised 2/03
PVElite/CODECALC 2005 QA Manual
CAESAR II Technical Reference Manual
CAESAR II User Guide
CAESAR II Application Guide
PAULIN RESEARCH GROUP FALL 2005 FINITE ELEMENT PRESSURE VESSEL & PIPING: Nozzle/Pro v6.0;Mat/Pro v1.0; FE/Pipe v4.2; Axi/PROv2.1; Mach PROv2.0.and BOS Fluids Version 4.111
FLUOR
PIPE STRESS ANALYSIS DESIGN GUIDES DESIGN OF ENGINEERED COMPONENTS
SEMINAR by ASME Professional Development Program:
ASME SHORT COURSE PROGRAM ASME SECTION III, CLASS 2 AND 3 PIPING ANALYSIS January 14-16 1992 Instructor Gerry Slagis.
ASME Section VIII, Division 2 Pressure Vessels November 13-16 2000, Instructor –Kam Mokhtrian, P.E Orlando, FL
ASME SHORT COURSE PROGRAM ASME Section VIII, Division 1 Pressure Vessels August 11-14, 1987, James R. Farr, Robert J. Cepluch, Denver, Colorado.
LOSS PREVENTION PART VI Pressure Containing Sizing Rupture Dices For Vessel containing Monomers, G. Harmon and H. A. Martin Rohn and Hass Company February 15-18 1970.
ASME SHORT COURSE PROGRAM EXAMMPLE DESIGN PROBLEM August 14, 1987, James R. Farr, Denver, Colorado
Reference:
The Design of Vertical Pressure Vessels Subject to Applied forces by E.,O.
Bergman, Alhambra, Calif.
ASME SHORT COURSE PROGRAM Alteration and Repair Procedures for Boiler and Pressure Vessels August 10, 1987, Cepluch, Denver, Colorado.
ANSI/ASME SHORT COURSE PROGRAM B31.3 CHEMICAL PLANT AND PETROLEUM REFINERY PIPING, September 22- 24, 1986 Instructors: Glynn E. Woods, P. E., Ronald W. Haupt, P.E. New Orleans, Louisiana.
A Wall Thickness Formula for High-Pressure High-temperature Piping Paper No 52-A-151
Piping-Flexibility Analysis By A.R.C. HARKL, Louisville, KY
Fatigue Texts of Welding Elbows and Comparable Double-Miter Bends By A.R.C. HARKL, Louisville, KY
Fatigue Texts of Piping Components By A.R.C. HARKL, Louisville, KY
Primary Stress Comparison ANSI B31.1 vs. ASME III Class 2 Item 21340 Design Subgroup Minutes, Jan 20 1982.
PFI Standard ES-7 October 1980
ANSI/ASME SHORT COURSE PROGRAM B31.1 Piping Design and Analysis July 24- 26, 1986. Instructors: Ronald W. Haupt, P.E. and Philip D Flenner, Chicago, Illinois.
ASME SHORT COURSE PROGRAM ASME BOILER AND PRESSURE VESSEL CODE: SECTION IX WELDING AND BRAZING QUALIFICTIONS, February 23-25, 1988, Instructors: Walter J. Sperko, P.E., Michael J. Houle, Houston, Texas
South Texas Section of ASME Advanced Piping Stress Analysis Seminar
Approximate Stress-Concentration Analysis for Pressurized Branch Pipe Connections, N. C. Lind
Design of Radial Nozzles in Cylindrical Shell for Internal Pressure, W.L. McBride and W.S. Jacobs
Local Stress in Spherical and Cylindrical Shells due to External Loading, K.R. Wichman, A.G. Hopper and J.L Meshon
Local Stress in Cylindrical Shells due to External Loading on Nozzle-Supplement to WRC Bulletin No 107. Kam Kokhtarian J. L. Marshon, G.V. Ranjan and E.C. Rodabaugh
Support for Horizontal Tank and Pipe Line Stresses in Large Horizontal Cylindered Pressure Vessel on Two Saddle Support, L.P.Aick in Chief Engineer CBI Original Paper published in September 1951 WRC Supplement..
Bowing of Cryogenic Pipelines, W.G. Flieder, J.C.Loreia, W.J.Smith
CHEVRON ANGOLA NORTH NEMBA Piping Stress Analysis Criteria
Piping Vibrations, J. C. Buddy Wachel, Engineering Dynamic Incorporated San Antonio, Texas
Vibrations in Reciprocating Machinery and Piping Systems Engineering Dynamic Incorporated San Antonio, Texas
Displacement Method for Determining Acceptable Piping Vibration amplitudes Engineering Dynamic Incorporated San Antonio, Texas
Design of Clamp Connections Frank C Adamek ASME Appendix 24
Analysis of Clamp-Type Separable fluid Connectors for Nuclear Vessel Application 68-PVP-13
SEMINAR by NATIONAL BOARD OF EXAMINATION:
Pre- Course Study Guide for Boiler and Pressure Vessel Inspector’ Training Course August 29, 1994. Ivy Tech State College Terre Haute, Indiana
Introduction Project Management Seminar Exxon Research and Engineering Company, Esso Production Libya, 1983, Marsal Brega, Libya
Disasu Vessel Design Estimating automated Drawing, 3D modeling for vertical /Horizontal Vessel, Stacks, Tanks, Flanges, WRC 07, August 1998
SEMINAR by API
API Standard 653:
API Standard 653 Aboveground Storage Tank Inspector Certification Examination, DHA Inspecting Services, Inc.
Introduction training on API standard 620, 650, & 653, and AST Emission March 27-29 2001 San Antonio, Texas.
ASME/API 579: Fitness-For Services Instructors: Ted Anderson, November 1-3, 2000
API 579: Fitness-For Services Instructors: David Osage, March 5-7, 2001
AIR EMISSION FORM ABROVEGRO0UND STORAGE TANKS A WORKSHOP Instructors: Rob Ferry the TGB Partnership March 28, 2001 San Antonio, Texas.
Pressure Relieving System Seminar “Application of Relief Devices” September 15-16, 1998 Houston Texas
API RP 520 PART 1 AND 2
API PR 521
API RP 526
API 2000
Risk-Based Inspection Base Resource Document API 581 May 2000
API 653 Review Course Presented by Codewest, June 13, 1994, Instructors J. W. COLEY, Houston, Texas: API 650, API 651, API 652, API 650, API 572 PUB 2015, PUB 2207, IRE, ASME V NDE, ASME IX WELDING.
API 510 CODEWEST November 1993
NACE:
Coating Inspector Training and Certification Program Lever I
Coating Inspector Training and Certification Program Lever II
ASNT
Ultrasonic Inspection Level I, Krautkaramer
Ultrasonic Inspection Level II, Krautkaramer
MAGETIC PARTICAL INSPECTIN SEMINAL MY 7,14, 21, 1994
Radiographic Film Interpretation of Weldments Course April 28-29 1995
AWS (AMERICAN WELDING SOCIETY)
WELDING INSPECTION TEDHNOLOGY Cincinnati, Ohio March 7-12 1994.
AWS WELDING HANDBOOK
