RE
Chemical
- Nov 15, 2002
- 5
I am working in natural convection on a vertical plate. The problem is how to calculate the heat transfer coefficient. Invariably text books give correlations bassed on Nusselt, Grashof, and Prandtl numbers for a hot plate in a cold fluid (gas or liquid). What happened with a cold plate in a hot fluid? It is correct to use the same correlations? I suppose the mecanism of heat transfer is quite different. How to calculate in this case the temperature difference for the Grashof number?,...(T fluid - T plate) ?
Thank you.
Thank you.
