Interesting.
I started this thread just seeing if anyone had any really good methods, figures or even, though I’m loathed to admit it, sound bites that justify having drawings go through drawing check. Thanks to those that came up with ideas on this.
It seems to have turned into a discussion of whether or not checking is worthwhile.
My opinion, for what little it’s worth, is that drawing check is invaluable; and if you have high enough thru-put to justify it then having dedicated checking staff is the best option.
As such my post was more to find ways of justifying it to management, especially those who don’t know the sharp end of a CAD package from Pac Man.
I guess I didn’t make it clear, or perhaps it’s just a logical continuation of the thought process, I went into it with the pre conceived notion that drawing was invaluable and that I just wanted to justify it, others have reversed the question and asked if it’s even worthwhile and perhaps it can’t be justified.
Finally does having a checker lead to bad work? If you were a high wire walker would your mind be more focused knowing you did not have a safety net?
Does having traffic police lead to bad driving? Presumably if they all passed their driving test then they know better and don’t need checking up on. At the very least surely traffic enforcement don’t need to worry about checking on Truck & Taxi drivers as they are ‘professionals’ and so will presumably step up to the plate?
As an extension of this, does having law enforcement lead to lawlessness?
There is a slightly trite, though arguably true saying I’ve heard on this subject.
People do not do what you expect, people do what you inspect.
The best engineers and drafters I’ve worked with made mistakes, perhaps fewer in number, but mistakes none the less. If most publishing houses can justify proof readers then is it too much to expect the same for drawings?
There is no point having drawing standards and conventions if no one enforces them. If you abandon conventions then just think how long it would take to detail a drawing in such a way that it cannot be misinterpreted.
Just my thoughts, probably not worth the paper they’re written onJ.
