Ganfoss2
- Oct 23, 2007
- 32
Dear all,
I need to clarify the following issue: if a "discontinuity" (like a saddle, a "small" opening to drain/vent the shell/channel chamber, a "large" opening for the INLET/OUTLET of the Process Fluid, ...) may be "close" to an INTEGRAL tubesheet ["close" mean distance less than: 1.8 x RADQ (D x t)] when the shell/channel thickness is used as "reinforcement" to reduce the tubesheet thickness ?
(See UHX-12.5.10 and UHX-13.6 for references)
I was not able to find any of such constraints in ASME VIII-1: the only available "criteria" is an extrapolation of the MIN. Distance between two LOCAL AREA of DISCONTINUTY (where S >= 1.10 x Sm) stated in the ASME VIII Div. 2 Code (Ex. Appendix 4).
Does someone has a "criteria" to suggest? I see very often request of quotation of Exchanger with "large nozzles" or "Supports" very close to an Integral Tubesheet with reduced thickness ("clamped" at shell/channel shell barrels ends).
NOTE: The New European Codes (EN-13445/3) and other Old EU National Codes (Ex. BS-5500, VSR) state a MIN distance respect to a "discontinuity" (Flange, Cone-to-Cylinder attachment, .... )!
