Since NX5, it's no more possible to trim with a cylinder or a cone inside the menu.
I found a work around with the copy/paste function
- I open an NX3 part with a trim by cylinder feature
- I select this feature then ctrl+C
- I create a new part in NX5
- I create a sample block for example
- Then ctrl+v to paste the trim
- I am able to modify the trim parameters
It's also possible to create an UDF to simplify the procedure.
But does anybody have another solution or a grip program to retrieve this function ?
Thanks in advance
Didier
Thanks in advance
Didier
