I am building a line operated DC power supply for a 48V DC pump designed for battery operation. The power consumption will range from about 250W to 500W depending on water level. A secondary objective is to keep power consumption low to minimize battery backup/inverter loading, and to minimize turn-on surges.
For best efficiency I have selected a 1 KVA toriod power transformer by Plitron. This size puts the power consumption range in the high efficiency portion of their performance curve.
They warn of exceptionally high inrush current because of the charicteristics of the core and recommned doing something about, it but provide no concrete advice.
I am looking for a soft start approach for the primary side of the circuit. I have seen two approaches; a thermistor and a resistive load disconnected by a relay (or thyristor - relatively high power loss) after a few cycles. Neither of these would protect against a very short power cycle and both involve power losses. Thermistors/thyristors while the pump is running and the relay all the time. I have seen some clever approaches from the secondary side but that does not fix the transformer charging current.
Any suggestions for an approach?
