Transfer Geometry From APDL
khabiran
Marine/Ocean
IR
Hi
How is it possible export mode shapes in APDL, as surfaces?
I try to have mutual interaction between Ansys AQWA and APDL or AQWA and ASAS....
BR
You can't export the solid model (ie surfaces, volumes) but you can output the FE model (nodes, elements) using UPGEOM and then write out the model using CDWRITE (or perform subsequent analyses on the FE model in ANSYS).
See faq569-1083 for details on how to make best use of Eng-Tips.com
