msmedesign
I have been performing mechanical test on speciments from the actual product to verify mechanical properties of WCB cast parts. About 50% percent of the test results were lower than ASTM A216 WCB requirements. (within 10%)
I tested the foundry samples for the same heats and found all of them within the ASTM requirements.`Samples from foundry have been in the same heattreated.
Cross section of the parts that they fail the tensile test does not show any indication of local casting void which may lower the mechanical properties.
Micro edge test performed on each parts and all of them are ok. ( meets heat treatment requirements)
Both elongation and reduction area is within ASTM A216 WCB requirements.
Please let me know if it is OK to have lower mechanical properties on the actual product testing. Is there any technical article which explains the reasons, or if any body had similiar experience.
