macduff
- Dec 7, 2003
- 1,255
I have a some-what complex part that I want to modify the base feature (the first extruded solid built) from a "thin feature" to a "closed feature". When I went to edit the part the "thin feature" box was un-selectable. So I expanded "selected contours" and defined the inner area I wanted to extrude. The "thin feature" box was now selectable and unchecked the box. When I went to exit out (I hit the green check) of the "edit feature" mode, nothing happened and went back to its original state. I tried to "edit feature" again and the "thin feature" box was checked. Is there any way to change this or do I start from scratch? Does this call for an enhancement request?
I did some searching on past threads, but only found "thin feature" for a revolution.
Thanks in advance for your help
Macduff![[spin] [spin] [spin]](/data/assets/smilies/spin.gif)
Colin Fitzpatrick
Sr. Mechanical Designer
macduff's SW page
Inhouse System
Pentium(4)2.80GHz
Ram 1.00 GB
SW2005 Office SP 3.1
Windows 2000 SP4.0
NIVIDA Quadro4 750 XGL
Macduff
Colin Fitzpatrick
macduff's SW page
Inhouse System
Pentium(4)2.80GHz
Ram 1.00 GB
Windows 2000 SP4.0
