Thermal difference Ansys APDL
Eng.Arg
DE
Hi everbody,
Please i need help by apllying an ambient temperature ΔT to my component on Ansys APDL.
it is a 3d rectangle = 40*40*60mm and i have to apply the ambient temperature difference ΔT = 125K and analyse the deformation in Z direction.
(Material : Steel, Temperatur (T0) = 0K )
more information in the picture attached.
thank you very much
 https://files.engineering.com/getfile.aspx?folder=5370b57e-3583-4b2e-81b8-14734c052028&file=Rectangle.jpg
Here is a sample code (you would need to change the dimensions, properties, and boundary conditions), which you can use once you have changed it:
Code:
/clear
/prep7
W=1	! Width
L=1	! Length
TH=0.2	! Thickness
ET,1,SOLID185
MPTEMP,,,,,,,,  ! Material prop.
MPTEMP,1,0
MPDATA,EX,1,,200E9
MPDATA,PRXY,1,,0.3
MPDATA,KXX,1,,51
MPDATA,ALPX,1,,0.0000115
BLOCK,0,W,0,L,0,TH,	!Define a block
ESIZE,0.05,0	! Mesh
VMESH,ALL
!NSEL,S,LOC,X,0	! Select nodes and apply BC
!D,ALL,UX,0
!ALLSEL,ALL
!NSEL,S,LOC,X,W
!D,ALL,UX,0
ALLSEL,ALL
NSEL,S,LOC,Y,0
D,ALL,UX,0
D,ALL,UY,0
D,ALL,UZ,0
ALLSEL,ALL
BF,ALL,TEMP,150	! Applies nodal temp. of 150 on the whole body
/SOL
ANTYPE,0
TREF,0	! Ref temp is 0 here
/STATUS,SOLU
SOLVE
FINISH
