I have been playing around with the idea of deriving stress concentration factors from finite element models and have some questions.
I have a simple model of a plate with a hole with an axial load applied. As I refine the mesh near the hole, the stress concentration factor I derive from my FEM model converge to what it should be (according to Roark). This works for simple geometries with simple loading.
Continuing with the plate with the problem of plate with a hole under axial loading:
My understanding is that as the loading increase, the stress near the hole will increase till it eventually exceeds the materials elastic limit. At that point, local plastic yielding occurs and the stresses near the hole remain constant while the stresses at a distance increase. This happens until the entire width of the plate is yielding and failure occurs. I believe that standard static analysis relies on this form of failure in that it doesnt account for stress concentration factors. It simply takes the axial load applied and divides by the effective area. This should work only for somewhat ductile materials as they should follow the failure process i described above.
My questions are the following:
- Finite element analysis accounts for stress concentration factors with the model geometry. Would it be theoretically correct for me to take the stress at stress concentrator locations and divide by the stress concentration factor? This would be equivalent to standard static analysis that i described above. This would assume simple geometries with known stress concentration factors that have simple loading with stresses that have converged. Im assuming theres no way to apply this to complex geometries with complex loading as there would be no way to determine what the stress concentration factor should be.
- Can you think of any papers or studies that detail how the stress concentration factors derived from a FEM converge as the mesh is refined? Or how this could be applied (or not) to more complex geometries with complex loading?
