I am designing connections for steel "W" shape pieces to concrete shear wall. Most of the connections are shear only and have no moments or axial forces.
1. The EOR requested that we also take the moment at the steel/concrete interface due to that shear loading. If the geometry is such as specified in AISC 13th Ed. we would take out the moment in the bolts/welds on the beam or outstanding leg, but not at the concrete embed.
2. My shear connectors are double angles (L8X6X1/2)
3. Because the embeds were misplaced in the field, I am thinking about securing the double angles to the wall using HILTI anchors.
4. The angles are either field-welded or bolted at the beam webs.
The questions are:
1. Is this still considered a simple shear connection, or these angles are now subject to a moment force?
2. What kind of design checks do I need to make here? Other than the standard, shear yield, rupture, prying, weld/bolt strength as described in AISC's 13th Ed.
3. Should I be checking the outstanding angle legs for the moment due to EOR's request to apply the moment at the embed due to the shear loading?
Any ideas or literature suggestions?
Thank you all.
