Self circulation low volume liquid coolant system
Hawxxy
Computer
GB
Im trying to figure out if it were possible to have a closed curcuit liquid cooling device with one directional valves that prevent backflow and keep it under 10cc for hand held CPU chips.
like so. I just dont know the thermodynamics of the avaliable coolants. this system is reliant on the expansion and compression of the coolant to circulate so unless there is a coolant that can both expand and be compressed I suppose it wont work.
here are the numbers.
CPU temperature unrestrained <80*C
connecting surface area 30 cm2
coolant avaliable 10 cc
questions:
would it circulate?
How high would the pressure be?
would it be able to reduce the temperature at least 50%?
Look into heat pipes. They rely on low boiling point fluids and use a wick to feed the liquid back. No valves or other parts.
Plymouth Tube
try to read up on heat pipes. note, however, you have a certain power that must be removed, which requires a sink that can accept that power with the temperature differences you have.
TTFN
faq731-376
7ofakss
I see. my problem would be that I rely solely on room temperature air to absorb the excess heat without a fan or any other moving part. the construction needs to work without consuming electricity. But it seems a heat pipe with ammounia would work. how long would it need to be to be effective at room temperature?
Whats wrong with a suitably sized heat sink using natural convection only? Why liquid cooling?
No one can really answer your questions as there are too many variables missing. thermal resistances/watts dissipated,etc...
heat pipes work great in ambient conditions to move heat from 1 area to another.
Hire an Engineer familiar with heat transfer to do this.
Also read forum policies which read as follows:
>>These fora should not be used to bypass your own in-depth research on the issues that affect you, nor is it intended to be >>a substitute for appropriate professional assistance within your field or geographical region.
