marioooo16
Geotechnical
Hi all,
I have a question regarding analysis of so called 'sand boiling' under the embankment. On existing embankment there is an issue where water appears on the bottom of the slope due to internal erosion of sand in upper layers, below is gravel. Any ideas how to model this in seep (geostudio)? which BC to use to simulate this. I've tried to do something and I can obtain hydraulic gradient which can be considered as cause of sand boling, but when I model an interface which should simulate cutoff, these gradients are even larger. Any ideas?
Thanks!
Thanks!
