Wooden retaining wall with dead man anchoring
Geofernie
Geotechnical
I'm analyzing an existing wooden retaining wall with dead man anchorage. I have scoured the internet for design methodology, has anyone had success. I have assumed that the shear capacity of the units is the shear capacity of the 15M rebar that was dowelled into each course at 0.6 m centers + N*tan(friction angle of wood on wood (internet suggested 14 degrees). Am in in the right direction? Should preface by saying I'm checking this as if it were an MSE wall.
How tall of a wall are you checking?
Most of the resources I have seen are either rules of thumb or for crib walls. There is very little out there for calculating the internal stability of a wooden deadman system.
what type of wall is it? upload pictures and a cross section/sketches
You cant just assume 14 deg, without knowing the actual angle, you will need to do a sensitivity check and pick worst case
The following web site providing useful info. It is not a common practice in my zone. The proposed max. height 6 ft. Apparently this is a DIY project .
Here are some resources on crib walls that I have extrapolated for designing walls with deadman anchors.
