CHARLESCOSTA
- Aug 26, 2007
- 27
A 30kw motor that was supplied along with the original 70mm
plate bending m/c has burnt out.Right now we only have a 60 kw motor as a replacement. Both are slip ring 975 rpm motors.Assuming that the factor of safety on various mechanical components like gears ,shafts etc used in the m/c is 1.5 for static strength,does any one forsee any possible damage that is likely to be caused to gear box,rolls etc by this replacement .Use of m/c is infrequent (say once in a month).
