How do you convert your load (in volumetric flowate and TDH)for an oil system to select a pump on a pump curve that was built with water? Can you simply convert the TDH in terms of POL to a TDH in terms of water and use the same flowrate and then build/overlay your system curve on the pump curves? Appreciate any help. Thank you.
