Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Thank you sir, so for attached set up, the rotation should be the one shown on pump name plate(shown as red arrow)? And can we say we have suction lift here?10. ROTATION The M-Range of Industrial pumps is suitable for rotation in either direction, i.e. flow direction out either of the pump flanges. The bearing housing direction plate indicates the resultant flow path dependent on mainshaft rotation direction. Pump flow curves also indicate flow direction. NOTE: It is recommended product flow is directed out the “end cover” (opposite drive end) side of the pump in applications where: • Pressure above 10 bar is required (dependant on pump capabilities) • No suction lift is required. For Suction lift applications, delivery must be on gland.
Hi Pierreick,Hi,
Check the manual and or ring the manufacturer.
Why will it be different from the past, your pump has been running for quite a while?
Weird to me.
Pierre
