I have a requirement to mount a pump on Stilts with springs and sliding pads for the following reasons
which can be found in the HI web site.
· Spring mounted bases provide vertical displacement
under applied loads associated with thermal expansion of the piping.
· Optional addition of slide bearing plates may also be provided below
the stilts or springs to allow horizontal displacement associated with
The pump is a OH2 type with 55Kw motor at 2900 RPM and with VFD. Baseplate is heavy duty per API design. Total weight is about 1200kg. Operating temperature is 150C.
Appreciate if you can share your experience of such arrangement.
Who are the supplier of such mounting system?
Thanks !
Thanks !
