Dear All
I am working on a dewatering assignment for a seawater-filled chamber that is 13 meters deep from ground level. I need to dewater it. For that, I received a data sheet from a pump supplier, which is attached here. I am scratching my head to understand below two data.
1) If my static head is 13 meters and the dynamic head requirement is approximately 3 or 4 meters. Can this pump work for me since its minimum head is given as 20.2 meters and max is given as 32.3 meters? My question is what if the maximum head required is less than the minimum head of the pump?
2) In the pump curve of the proposed pump in addition to the pump curve in blue, there are two graphs in black color. What is it? I couldn't understand it. I contacted the supplier. But unfortunately, he is not a technical person. He couldn't help me more
