ProE and ATI GL2 graphics
  • Thread starter Thread starter -
  • Start date Start date
Guest
has anyone had problems running ProE 2000i2 on a Dell workstation with an ATI GL2 Fire graphics card.
We use other viewers for lightweight data; but we wind up seeing the ProE splash screen....any thoughts? config settings, etc??
We have one that has been running for about a year without incident. Just switched to Pro/E 2001 and no problems there either. I can post the driver versions if you like.
Jeff
Hi Jeff,
thanks for the response (was this on a dell machine like
a 330 or 530?)
That would be great if you could post the drivers or versions..
thanks
j
In Pro-E while changing the display mode to shade the Pro-E gets exit.Is there any settings to change.I am running the Pro-E on WinNT4.0 Thanks in advance
Senthil
I recall seeing some tech notes in the knowledge base regarding your card, I think. It could be version-specific...if the new drivers and/or setting your config options correctly don't work, I would try installing a newer date code for the version you are running.
Recneps
