ahakim98006
I am having an issue with plots. If I write a function that uses units of force the function evaluates correctly but the plot does not. If I use mass units both work fine. Attached is a pdf sample of my problem.
I have set the units system to custom, based on SI, with the length unit changed to mm.
Thanks for any help.
