diggingdeeper
my client has a warehouse which he wishes to sell with 70' span bowstring trusses, several of which are broken. the top chord is 4-2x6s flat, apparenetly nail laminated together as no bolts are visible. the bottom chord is a single 6x6 spliced in the middle. the webs vary from 3x3 to 3x4. the panel point connections are a U plate configuration with a single bolt through each web and the wings of the "U" and two bolts through the base of the "U" and through the chord, top or bottom. the heel appears to be a thrust plate receiving the top chord and welded to two side plates bolted through the bottom chord.
i would really appreciate any insigths into these trusses, particularly in the analysis of this type of panel point system. thanks!
