braddles90
Hi all,
Just wondering whether anyone else has seen this glitch? When I'm in drafting mode, say I have a rectangular plate with an 8 hole pattern through it, and I put a section through the plate to show the holes through the thickness of the plate. I put two 2D centrelines through the holes in the section, then when I go to put a Cylindrical dimension between the centrelines to show the PCD, the dimension doubles the actual value (i.e. if the PCD is modelled at 100mm dia., the dimension will show up as dia. 200).
Hopefully my example is clear enough (I can post a sketch if needed) - anyone able to say they've seen it before, or why it does it? It's a pretty annoying (and potentially dangerous, because I've only just caught it a couple of times after checking the drawing)!
Thanks!
Thanks!
