NX2 Note Created in Modeler not showing up in Drafting
MIKENEUTRON
Automotive
I have notes that I created while not in sheet view.
When I add a new view to the drawing, the notes do not show up.
Any thoughts on how to get the notes to show up?
Such notes are created as 'view dependent', they only show up in the view in which they were created. Turn off the drafting sheet and go to Information -> object to see this for yourself. In the first section (after layer, type, color, etc) you will see "View dependent in <view name>". If you want this note to show up in every view, go to Edit -> View -> View dependent edit... choose 'convert dependency view to model' and pick the note.
Just noticed you are on NX2. Menu items may have moved (I'm on NX 7.5) but the overall procedure is the same.
