New attributes are not appearing in the Title Box
MFDO
217
When I created a drawing, the Master Model didn't contain attributes required to fill up the drawing Title Box. I noticed this because required texts didn’t appear in the Title Box. Then I went back and populated the necessary attributes (copy and paste from another model) in the master model. Still I don’t see them appearing in the Drawing Title Box.
Any idea of this behaviour?
Michael Fernando (CSWE)
Tool and Die Designer
Siemens NX V10.0 + PDW
SWX 2013 SP3.0 X64
PDMWorks 2013
Logopress3
FastForm Advance
FormatWorks
Easiest method would be to add a new drawing sheet and move your views to the new sheet. You can the delete the first sheet and rename the new sheet.
There is a more complicated method where you edit each piece of attribute text on the drawing to eliminate the "?" that appears in it and verify that they are correct (at least that's the way it used to be; haven't gone that route in years).
"Know the rules well, so you can break them effectively."
-Dalai Lama XIV
