Mol Sieve Dehydrators - Removal of Water in KO Drum/Filter
EmmanuelTop
Chemical
Sep 28, 2006
1,237
Good day to everyone
I am looking for first-hand experience data regarding water KO drums and coalescer elements used in Natural Gas dehydration service (liquefaction plant), located upstream of Mol Sieves.
1. What is the maximum expected efficiency one can get with state-of-the-art internals? I was quite surprised to calculate (field measurements) <98% overall water removal efficiency in the KO drum equipped with Schoepentoeter, Mesh, and the vane pack.
2. I've heard that two-stage filters (candle filters + vane pack) are not efficient in removing >99% of residual water from the gas stream, as claimed. Can anyone suggest something that works better?
3. Undersized gas outlet nozzle. Based on our calcs, the momentum of gas exiting the vessel is well above 4,500 Pa (more than 40% higher). What are the effects of undersized gas outlet nozzle? Can they promote upset/dislodging of vessel internals?
Because of carryover onto Mol Sieve beds, we are considering to install a guard layer of Sorbead (as a temporary measure). We would like to solve this problem by hitting on the right place - and that is water removal system upstream of Mol Sieves - rather than just treating the consequences.
Thanks,
