I need to obtain the minimum thickness of a flat carbon steel plate under the following conditions:
1) Circular bottom plate (radius = r) under uniform pressure P, and the plate is fixed at the periphery.
2) The plate is resting on the soil, and the soil has enough bearing capacity to prevent deflection of the plate.
3) Since I want my deflection to be "0", the plate will be only under simple compression load.
Is there any formula or method to calculate the required thickness under this conditions (compression load) ?
Thank you !
Nikk5
Thank you !
Nikk5
