Macro to insert DWG
bpeirson
CA
I would like to know how to have Excel insert an AutoCAD drawing into a worksheet depending on the part name typed into a reference cell.
I have hundreds of different part numbers/names. I would like the worksheet to be a template to be used for different jobs with different parts for different clients.
Assume that the name of the part will be the file name of the drawing and that all drawings will reside in the same folder.
Thanks in advance for any pointers.
The only way I think this can be done is to first use a script in AutoCAD to export the image as a metafile or .jpg
then in excel use a VBA cell event to import the image.
Sorry not sraight forward an will require a small amount of both VBA programming and AutoCAD scripting/AutoLISP
Another option is to purchase a very inexpensive program called Better WMF from Furix. It works by installing an .arx application file on the AutoCAD directory. From the command line, you type "BWMFOUT", and the program will export a .wmf to where ever you want. The file can then be inserted into Excel. Very good resolution!!!
