Mustafinho
I am looking to find the Snow Load in the Ontario Building Code (OBC) and looking at (Part 4 - Structural Design) 4.1.6.2. where the specified snow load formula is provided, I can't find the Ss, which is 1-in-50-year ground snow load (kPa) determined in accordance with subsection 1.1.2.
Subsection 1.1.2. in the OBC is the Climate Data. It requires Supplementary Standard SB-1 values from climate and seismic design values.
Similarly, the specified wind load also has a q value, which is determined in conformance with Subsection 1.1.2.
Normally, I use Jabacus to get both Snow and Wind Load values but I want to be able to use the OBC to do it manually.
I am guessing I might have to use the NBCC to get the values(I have never used NBCC at school/work) since most of the work was for Ontario.
Where can I find the climate and Seismic design values?
Thank you in advance for your input.
