Lateral Stiffness - Building frequency 1
blue82
I'm trying to get an idea of a buildings frequency, i've got a 70m high tower with a concentrated mass at the top.
Is there a rule of thumb when first considering its sway sensitivity?
Can i use f=1/2pi * sqrt k/M ? How do i go about determining it's lateral stiffness?
Thanks for the response, and nice blog!
Out of interest, what is an acceptable frequency? I'm getting around 0.4Hz
The frequency is a determinant of the wind and seismic forces, so in part your lateral force resistance will determine what's acceptable. Otherwise you'll have to examine whatever code you're using for frequency/deflection requirements for towers.
Brian C Potter, PE
Structure Magazine has a article on Building periods that you may find helpful: . Note that different approximate periods (inverse of frequency) are used for wind and seismic. ASCE 7-10 has some equations for both. The equations depends upon what type of lateral force resisting system is used. These could be used as a starting point. What percentage of the total building mass is concentrated at the top?
Thanks for the information,
It's an airport control tower, so its basically a 70m stairwell and then 3 cabs at the top.
