I'm doing some refresher reading on reinforced concrete design, and an interesting question popped up.
When an uncracked concrete beam reaches the concrete tensile strength in a tension zone the concrete cracks - leaving your reinforcing steel to handle the tensile stresses.
Now, when this occurs is there any appreciable 'shock loading' on the steel.
I figure there won't be any noticeable effect for a run-of-the-mill design, but if you were to have a hybrid system with fibre in the concrete as well as rebar, if the concrete were to let go it could yield the bar well below a constant 400Mpa stress.
Thoughts?
Thoughts?
